BGP: 1 ASN different Network
hi all,
i want ask about BGP at mikrotik.
i have 2 link backbone, at mikrotik i have 3 interface :
public-1
public-2
gateway
then i have 1 ASN, i want advertise my blok IP a.a.a.a to public-1 and blok IP b.b.b.b to public-2, is mikrotik can do this?
yes, with routing-test you can have multiple peers, each with their own filters.
Sam
ok i have download it, where i can get manual off routing test.thanx
The bgp manual is not 100% complete, but is updated to include the newer commands. You can find it on the documentation site under BGP / routing.
If you are having a specific problem with the config post your details.
