BGP advertisement
Hello
I am adding a new route and its very simple from a router to router, but on this new router, the peer is up with 2 prefix count but i cannot see them in advertisement, i have checked filters and removed them but I cannot see the sub nets advertised. Any help ?
thanks,
Depends on config. Typically VPNv4 routes are not visible there or any routes were “main” routing table is not used.
same config with other router and the route shows up, its ipv4 nothing fancy, if i add one more block for advertisement it appears on other router but not this one, i have removed filter to test but still the routes so not show up .
