BGP and Equal-cost multi-path routing (ECMP)
Hi All.
I have been fighting a setup in my lab for a good few hours now trying to get Equal-cost multi-path routing (ECMP) working with BGP.
Is this an option on RouterOS at this time?
Thanks.
Take a look at this … http://wiki.mikrotik.com/wiki/Manual:BGP_Load_Balancing_with_two_interfaces
(check the notes at the bottom of the page).
Regards
Faisal
Yes, RouterOS can ECMP up to 128 paths. Because BGP in RouterOS does not support ECMP, you must use loopbacks for peering and static routes or OSPF to get ECMP with BGP.
