I am running RouterOS v.7.2rc4 (but it was the same on v7.1.3) on a CCR2004.
When I configure an eBGP session (receiving a DFZ full routes) and after the device has established the connection, if I modify the prefixes to be sent by modifying the “output filter” to point to my list, the router does not “refresh” the routes to be advertised unless I manually teardown and re-establish the session.
Is this a known problem of RouterOS v7 and is there a fix for it or am I just doing something wrong?
I anticipate people asking about my configuration, below is a copy of the current test configuration.
I appreciate any hint.
Alex
/interface vlan
add interface=sfp-sfpplus1 name=vlan500 vlan-id=500
add bridge=bridge1 interface=vlan500
add bridge=bridge1 interface=sfp-sfpplus1
add address=BGP_P2P/30 interface=vlan500 network=BGP_P2P
add address=1.2.3.1/24 interface=bridge1 network=1.2.3.0
/ip firewall address-list
add address=1.2.3.0/24 list=bgp_mysubnet
add action=accept chain=forward connection-state=established,related,new disabled=yes
/routing bgp connection
add address-families=ip as=MYAS disabled=no local.address=BGP_P2P/30 .role=ebgp-customer name=ISP1 output.network=bgp_mysubnet remote.address=BGP_P2P_ISP/32 .as=ISPAS router-id=MYRID routing-table=main
