I have 2 questions regarding configuration of BGP in a routing test package (ver. 2.9.45) :
I have configured 2 BGP uplinks with redistribution of OSPF and static routes in BGP (instance). I would like to know how to “force” (or regulate) incoming and outgoing traffic primarily through one of those 2 links ? I tried to play with routing filters, AS prepend and local preference parameters without visible success. First I created rules :
2.
After few hours of production work BGP peers started changing state - from “connected” to “idle” every 20s.
Does anybody have experience how to prevent that ?
possibly the tcp session on port 179 is getting interrupted. Make sure there are no firewall rules blocking communication to these machines on port 179.
make sure that no one is nailing you on port 179 - possibly something is resetting the tcp session.
check your network between peers, possibly something is causing a break in activity ?
use packet sniffer and take a pcaket capture of the bgp peering session. This will tell you exactly what is wrong. if you need help decoding it I can help.
oh, one last thing … if your CPU is 100% that might be the problem. sometimes the router is too busy and forgets bgp is running (bgp crash). Do you see 100% cpu for long periods of time after bgp session is established, or only during route negotiation?
What I did I unscheduled “routing-test” package, scheduled back “routing” package and BGP with 2 uplinks works well !!! There are no interruptions and problems as those with routing-test and routing filters even if I do enable/disable ports and similar activities mentioned earlier.
The major problem is how to prepend AS path to one of 2 peers. Because we are using OSPF as our primary igp routing protocol I simply applied routing filters to ospf-in and ospf-out chains to a desired peer to reduce in/out traffic throught it. But if I start varying parameteres in “Matchers” section BGP peers are going “nuts” - they are flip-floping between idle/established states.
If there is AS path prepend option somewhere in a basic routing package personally I don’t need to use routing-test.
