I have a problem.
I’m an AS internet provider and i have my public IPs.
I have two internet “backbone” and i can use my public IPs on these two.
But i have to use the first’s backbone only for a range of my IPs ( from 1 to 100 ) and use the second’s for the other IP ( from 101 to 254 ).
I have a routed network with ospf for “intra-routing” and BGP for routing with the other AS.
I have a router that divide my network from the two backbone and i use policy routing for choose the correct. I have some other router from this gateway and the other provider.
Now i have to make an automatic system for route to the available backbone if one of this go down.
So i like that my ip from .1 to .100 are annunciated on internet from the BGP1_ROUTER and my ip from .101 to .254 on the BGP2_ROUTER. This for upload and for download.But if the BGP1_ROUTER is unreacheble (or BGP2_ROUTER) i like that the first range ( .1 to .100 ) are annunciated from the BGP2_ROUTER.
(BGP1_ROUTER and BGP2_ROUTER are connected to internet by two different provider)
do you have only a /24? in this case is difficult to announce only half to one ISP and the other half on the other, becouse prefix< 24 are filtered and dropped!!
if you have a /23 or >, you can split the announcement and announce the full /23 on both isp and a /24 for ISP; in this way the /24 is smaller and have precedence; if the isp will fall down, the /24 will not be announced and the whole /23 take priority!
this is the simple way!
for outgoing traffic you can use the route marking!
