Hello everyone, I’m trying to setup this scheme (followed wiki examples):
But for some reason I can get vpls up.
BGP/LDP - seems ok.
All routerboards are updated to 6.2.
192.168.22.0/24 - Net for management.
Doesn’t know what else I should check..
PE2-configured to act as route reflector.
PE1 Config:
[admin@PE1] > /export compact
# jan/02/1970 00:22:21 by RouterOS 6.2
add name=loopback
add name=vpn
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
/port
set 0 name=serial0
/routing ospf instance
set [ find default=yes ] router-id=10.13.0.2
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add address=192.168.22.130/24 interface=ether10 network=192.168.22.0
add address=10.12.1.17/30 interface=ether2 network=10.12.1.16
add address=10.12.1.2/30 interface=ether3 network=10.12.1.0
add address=10.12.1.6/30 interface=ether1 network=10.12.1.4
add address=10.13.0.2/32 interface=loopback network=10.13.0.2
/ip route vrf
add disabled=yes interfaces=ether1,ether2,ether3,loopback route-distinguisher=1:1 routing-mark=MPLS_VPLS
/lcd interface
set sfp1 interface=sfp1
set ether1 interface=ether1
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6 interface=ether6
set ether7 interface=ether7
set ether8 interface=ether8
set ether9 interface=ether9
set ether10 interface=ether10
/mpls interface
set [ find default=yes ] mpls-mtu=1526
/mpls ldp
set enabled=yes lsr-id=10.13.0.2 transport-address=10.13.0.2
/mpls ldp interface
add interface=ether1 transport-address=10.13.0.2
add interface=ether2 transport-address=10.13.0.2
add interface=ether3 transport-address=10.13.0.2
/routing bgp peer
add address-families=l2vpn name=pe3 remote-address=10.13.0.1 remote-as=65530 ttl=default update-source=loopback
add address-families=l2vpn name=pe2 remote-address=10.13.0.3 remote-as=65530 ttl=default update-source=loopback
add address-families=l2vpn name=cpe1 remote-address=10.13.0.4 remote-as=65530 ttl=default update-source=loopback
/routing ospf interface
/routing ospf network
add area=backbone network=10.12.1.16/30
add area=backbone network=10.13.0.2/32
add area=backbone network=10.12.1.0/24
add area=backbone network=10.12.1.4/30
/system identity
set name=PE1
PE2:
[admin@PE2] > /export compact
# jan/02/1970 00:24:54 by RouterOS 6.2
# software id = T6PG-8NKN
add name=loopback
set [ find default=yes ] router-id=10.13.0.3
add address=10.12.1.10/30 interface=ether2 network=10.12.1.8
add address=10.12.1.5/30 interface=ether10 network=10.12.1.4
add address=192.168.22.132/24 interface=ether9 network=192.168.22.0
add address=10.13.0.3/32 interface=loopback network=10.13.0.3
add address=172.16.0.1/24 interface=ether5 network=172.16.0.0
/ip route vrf
add disabled=yes interfaces=ether2,ether10,loopback route-distinguisher=1:1 routing-mark=MPLS_VPLS
add interfaces=ether5 route-distinguisher=2:2 routing-mark=test
/ip service
set api disabled=yes
/mpls interface
/mpls ldp
set enabled=yes lsr-id=10.13.0.3 transport-address=10.13.0.3
/mpls ldp interface
add interface=ether10
/routing bgp peer
add address-families=l2vpn name=pe3 remote-address=10.12.1.9 remote-as=65530 route-reflect=yes ttl=default update-source=loopback
add address-families=l2vpn name=pe1 remote-address=10.13.0.2 remote-as=65530 route-reflect=yes ttl=default update-source=loopback
add name=cpe1 remote-address=10.13.0.4 remote-as=65530 route-reflect=yes ttl=default
add name=cpe2 remote-address=10.13.0.5 remote-as=65530 route-reflect=yes ttl=default
add area=backbone network=10.13.0.3/32
/system identity
set name=PE2
PE3:
[admin@PE3] > /export compact
# jan/02/1970 00:26:01 by RouterOS 6.2
add name=loopback
set [ find default=yes ] router-id=10.13.0.1
add address=10.12.1.1/30 interface=ether3 network=10.12.1.0
add address=10.12.1.9/30 interface=ether2 network=10.12.1.8
add address=10.12.1.13/30 interface=ether10 network=10.12.1.12
add address=192.168.22.131/24 interface=ether9 network=192.168.22.0
add address=10.13.0.1/32 interface=loopback network=10.13.0.1
add address=172.16.0.2/24 interface=ether5 network=172.16.0.0
/ip route vrf
add disabled=yes interfaces=ether2,ether3,ether10,loopback route-distinguisher=1:1 routing-mark=MPLS_VPLS
/ip service
/mpls interface
/mpls ldp
set enabled=yes lsr-id=10.13.0.1 transport-address=10.13.0.1
/mpls ldp interface
/routing bgp peer
add address-families=l2vpn name=pe1 remote-address=10.13.0.2 remote-as=65530 ttl=default update-source=loopback
add address-families=l2vpn name=cpe2 remote-address=10.13.0.5 remote-as=65530 ttl=default update-source=loopback
add area=backbone network=10.13.0.1/32
add area=backbone network=10.12.1.8/30
add area=backbone network=10.12.1.12/30
/system identity
set name=PE3
[admin@PE3] >
CPE1:
[admin@CPE1] > /export compact
# jan/02/1970 00:26:53 by RouterOS 6.2
add name=loopback
add l2mtu=1598 mtu=1526 name=vpnA
/interface wireless
set 0 l2mtu=2290 ssid=MikroTik
set [ find default=yes ] router-id=10.13.0.4
add bridge=vpnA interface=ether2
/interface vpls bgp-vpls
add bridge=vpnA bridge-cost=5 bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=A pw-mtu=1526 route-distinguisher=1:1 site-id=4
add address=10.12.1.18/30 interface=ether1 network=10.12.1.16
add address=192.168.22.133/24 interface=ether5 network=192.168.22.0
add address=10.13.0.4/32 interface=loopback network=10.13.0.4
/ip route vrf
add disabled=yes interfaces="ether1,loopback,(unknown)" route-distinguisher=1:1 routing-mark=MPLS_VPLS
/ip service
/mpls interface
/mpls ldp
set enabled=yes lsr-id=10.13.0.4 transport-address=10.13.0.4
/mpls ldp interface
/routing bgp peer
add area=backbone network=10.13.0.4/32
/system identity
set name=CPE1
/system leds
set 0 interface=wlan1
CPE2:
[admin@CPE2] > /export compact
# jan/02/1970 00:27:34 by RouterOS 6.2
add name=loopback
set [ find default=yes ] router-id=10.13.0.5
add bridge=vpnA bridge-cost=5 bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=A pw-mtu=1526 route-distinguisher=1:1 site-id=5
add address=10.12.1.14/30 interface=ether1 network=10.12.1.12
add address=192.168.22.134/24 interface=ether5 network=192.168.22.0
add address=10.13.0.5/32 interface=loopback network=10.13.0.5
/ip route vrf
/ip service
/mpls interface
/mpls ldp
set enabled=yes lsr-id=10.13.0.5 transport-address=10.13.0.5
/mpls ldp interface
/routing bgp peer
add interface=ether1 network-type=broadcast
add area=backbone network=10.13.0.5/32
/system identity
set name=CPE2
CPE2 Output:
[admin@CPE2] > /mpls ldp neighbor print
Flags: X - disabled, D - dynamic, O - operational, T - sending-targeted-hello, V - vpls
# TRANSPORT LOCAL-TRANSPORT PEER SEND-TARGETED ADDRESSES
0 DO 10.13.0.1 10.13.0.5 10.13.0.1:0 no 10.12.1.1
10.12.1.9
10.12.1.13
10.13.0.1
172.16.0.2
192.168.22.131
[admin@CPE2] > /interface vpls print
Flags: X - disabled, R - running, D - dynamic, B - bgp-signaled, C - cisco-bgp-signaled
[admin@CPE2] > /mpls ldp print
enabled: yes
lsr-id: 10.13.0.5
transport-address: 10.13.0.5
path-vector-limit: 255
hop-limit: 255
loop-detect: no
use-explicit-null: no
distribute-for-default-route: no
10.12.1.9
10.12.1.13
10.13.0.1
172.16.0.2
192.168.22.131
[admin@CPE2] > /routing bgp peer print
Flags: X - disabled, E - established
# INSTANCE REMOTE-ADDRESS REMOTE-AS
0 E default 10.13.0.1 65530
1 E default 10.13.0.3 65530
CPE1 Output:
[admin@CPE1] > /interface vpls print
[admin@CPE1] > /mpls ldp print
enabled: yes
lsr-id: 10.13.0.4
transport-address: 10.13.0.4
hop-limit: 255
loop-detect: no
[admin@CPE1] > /mpls ldp neighbor print
0 DO 10.13.0.2 10.13.0.4 10.13.0.2:0 no 10.12.1.2
10.12.1.6
10.12.1.17
10.13.0.2
192.168.22.130
[admin@CPE1] > /routing bgp peer print
0 E default 10.13.0.2 65530
[admin@CPE1] > /routing ospf route print
# DST-ADDRESS STATE COST GATEWAY INTERFACE
0 10.12.1.0/30 intra-area 20 10.12.1.17 ether1
1 10.12.1.4/30 intra-area 20 10.12.1.17 ether1
2 10.12.1.8/30 intra-area 30 10.12.1.17 ether1
3 10.12.1.12/30 intra-area 30 10.12.1.17 ether1
4 10.12.1.16/30 intra-area 10 0.0.0.0 ether1
5 10.13.0.1/32 intra-area 30 10.12.1.17 ether1
6 10.13.0.2/32 intra-area 20 10.12.1.17 ether1
7 10.13.0.3/32 intra-area 30 10.12.1.17 ether1
8 10.13.0.4/32 intra-area 10 0.0.0.0 loopback
9 10.13.0.5/32 intra-area 40 10.12.1.17 ether1
Any ideas are very appreciated ![]()
