BGP. Beginner need help
SOLVED!!!
Hello!
I have my own PI and one uplink.
My Mikrotik settings are listed below (all IPs and numbers are little bit changed)
# nov/19/2012 13:30:05 by RouterOS 5.20
# software id = CFM7-FF9G
/routing bgp instance
set default as=166149 client-to-client-reflection=yes disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing bgp network
add disabled=no network=165.224.112.0/24 synchronize=no
/routing bgp peer
add address-families=ip as-override=no default-originate=never disabled=no \
    hold-time=3m in-filter="" instance=default multihop=yes name=bgp_westcall \
    nexthop-choice=default out-filter="" passive=no remote-address=\
    84.52.69.145 remote-as=25408 remove-private-as=no route-reflect=no \
    tcp-md5-key="" ttl=255 update-source=84.52.69.146 use-bfd=no
[admin@ClasterGW] > routing bgp peer print status
Flags: X - disabled, E - established
 0 E name="bgp_westcall" instance=default remote-address=84.52.69.145 remote-as=25408 tcp-md5-key="" nexthop-choice=default
     multihop=yes route-reflect=no hold-time=3m ttl=255 in-filter="" out-filter="" address-families=ip
     default-originate=never remove-private-as=no as-override=no passive=no use-bfd=no remote-id=106.197.165.127
     local-address=84.52.69.146 uptime=37m43s prefix-count=1 updates-sent=2 updates-received=1 withdrawn-sent=0
     withdrawn-received=0 remote-hold-time=3m used-hold-time=3m used-keepalive-time=1m refresh-capability=yes
     as4-capability=yes state=established
tell me please why i can not ping my sunnet for example 165.224.112.10 from World?
I will be grateful for the help
SOLVED!!!
The problem was in FailOver settings? because i use 3 World IP from different providers beside my own subnet (BGP).
So if somebody want to know HowTo so tell me what settings should I export and show.
PS.
Sorry for my English.
