I just finish my first configuration with my second peer and monitoring the best path algorithm in CCR 6.3 I cant understand this:
@MikroTik] > ip route print detail where dst-address in 173.252.96.0/19
41 ADb dst-address=173.252.96.0/19 gateway=201.163.MM.YY
gateway-status=201.163.xx.xx recursive via 201.163.yy.xx ether3 distance=20 scope=40
target-scope=30 bgp-as-path="YYZZ,3491,3549,32934,32934" bgp-weight=0 bgp-origin=igp
received-from=ISP2
14 Db dst-address=173.252.96.0/19 gateway=201.174.MM.MM
gateway-status=201.174.xx.yy recursive via 201.158.xx.yy ether2 distance=20 scope=40
target-scope=30 bgp-as-path="NNYY,32934" bgp-weight=5 bgp-origin=igp received-from=ISP1
You can see the bgp-as-path is smaller, also de bgp-weight its higher on the #14.
/routing bgp peer> print detail
Flags: X - disabled, E - established
0 E name="ISP1" instance=ISP1 remote-address=201.174.YY.XX remote-as=320YY
tcp-md5-key="" nexthop-choice=default multihop=yes route-reflect=no hold-time=3m ttl=255
in-filter=in-isp1 out-filter=out-isp1 address-families=ip default-originate=never
remove-private-as=no as-override=no passive=no use-bfd=no
1 E name="ISP2" instance=ISP2 remote-address=201.163.YY.XX remote-as=111XX tcp-md5-key=""
nexthop-choice=default multihop=yes route-reflect=no hold-time=3m ttl=225 in-filter=in-isp2
out-filter=out-isp2 address-families=ip default-originate=never remove-private-as=no
Please, someone knows whats its happening? Why the best path algorithm its taking the route with more jumps on the AS_PATH?.
Thanks!!!.
