dear experts
as you seen in above picture i divide my network into 3 AS,some links of routers are high speeder that the others and i wish to select the best speed way by default.Also some links have the best quality than the other links and i would like to select the best quality even if its speed is slower.
also i have some routers such as R3 that i would like to load balance between each two link.
Is any one that send the complete BGP Configuration of this network
Hi
why using BGP for interior routing and nots OSPF ?
in fact i’m in a network that already configured by BGP, but i’m not enough expert on it.i hope someone sole the above problem to get an enough knowledge about BGP
starting learning dynamic routing with BGP is not the fastest way
you can implement ospf
or you can use BGP trying to force routing with ‘local-preference’ and path ‘prepend’
Good luck
A+
Thierry
