BGP Communities & 32-bits ASN
Hello all,
I’m wondering if RouterOS 5.14 supports setting BGP communities XXXX:YYYY with XXXX being a 32-bits value (or a dotted value) ?
I can see that it accepts these BGP extended communities from another BGP speaker (not RouterOS) but I don’t know how to set it with Mikrotik products (neither from CLI nor WinBox).
Thanks in advance.
To send 32bit values you need to use extended communities.
You can use route-targets or site-of-origin to send extended community.
Thank you very much, I wasn’t looking at the right place :slight_smile:
