BGP communities filter issue
I have an issue with BGP community filter
I want to give only few communities to neighbour
What I am doing:
routing filter add chain=bgp-out bgp-communities=65009:0 invert-match=no action=accept set-bgp-prepend-path=“”
routing filter add chain=bgp-out bgp-communities=“” invert-match=no action=discard set-bgp-prepend-path=“”
routing bgp peer set peer out-filter=bgp-out
After that i have what i want, neighbour have only routes from community 65009:0. If i trying to give communities as list:
routing filter add chain=bgp-out bgp-communities=65009:0, 65012:0 invert-match=no action=accept set-bgp-prepend-path=“”
then neighbour have no routes, but i beilive that neighbour must have routes from communities 65009:0 and 65012:0.
what do i do wrong?
It sounds like the rule is requiring both communities, not one or the other.
From the documentation:
bgp-communities (integer:integer | internet | local-as | no-advertise | no-export;)
match the COMMUNITIES BGP attribute. Match is done when communities attribute in a route contains all entries from this configured list. But note that if communities list contains ‘internet’, the whole list always matched.
http://wiki.mikrotik.com/wiki/Manual:Routing/Routing_filters
Try putting 2 rules, one for each community that you want to allow out.
You could set up a testbed BGP peer so you could play with filters all day long and never break anything.
(make a test-out filter for that peer so you don’t accidentally change the real filter)
