BGP Communities from out
I welcome all!
There is such task:
there is 1 MT server on it 4 bgp of session (2 “piring” and 2 full view) come it is required to give on 1 more (5th) bgp session only “piring” networks. as I understand to make it it is possible only by means of communities.
can prompt as correctly to issue the filter?
Thanks!
I presume you are referring to ‘peering’. You can use communities but I suspect the simplest method for you at this stage would be to utilise the bgp “Out Filter” for the new 5’th peer.
I’m not going to go into extensive detail but I’d suggest the filter is maybe applied based on AS path of the peers.
Good starter references would be:
http://wiki.mikrotik.com/wiki/Manual:Routing/BGP
http://wiki.mikrotik.com/wiki/Manual:BGP_Case_Studies
What you’re asking for is more of an assist in terms of a commercial bgp consulting gig than a simple question in the forum :wink:
