I am trying to figure out a simple way to send a community string to my upstream provider. they say they need xxx:999 in order to handle anything less than a /24
I dont really understand this but anyway i need to send xxx:999
Set the BGP peer to use an outbound filter and manipulate the prefixes there:
add action=passthrough append-bgp-communities=65535:999 chain=ISP-out comment="append bgp-community=64512:999 where /32:" prefix-length=32
This is typically used to blackhole IPs within your announced prefixes and is generally pushed out to your ISP’s various entry points.
Herewith an assumption as to how your ISP is configured:
ISP’s ASN: 64512
Customer A’s ASN: 65535
Customer A prefix: 10.0.0.0/22
ISP’s blackhole community: 64512:500
Customer blackhole community: 64512:999
Overview:
add action=jump chain=CustomerA-in comment="Customer A:" jump-target=common-in-clean
add action=jump bgp-as-path="^(65535_)+\$" chain=CustomerA-in jump-target=common-in-client prefix=10.0.0.0/22 prefix-length=22-32
add action=discard chain=CustomerA-in
add bgp-communities=64512:0 chain=common-in-clean comment="Shared jump targets, clear communities where they contain ours:" set-bgp-communities=""
add bgp-communities=64512:500 chain=common-in-clean set-bgp-communities=""
add bgp-communities=64512:3000 chain=common-in-clean set-bgp-communities=""
add bgp-communities=64512:4000 chain=common-in-clean set-bgp-communities=""
add action=accept append-bgp-communities=64512:500 bgp-communities=64512:999 chain=common-in-client comment="Shared jump targets, append bgp-community=64512:500 (blackhole) where community=64512:999:" prefix-length=32 set-type=blackhole
add bgp-communities=64512:999 chain=common-in-client comment="clear communities where community=64512:999:" set-bgp-communities=""
add action=accept append-bgp-communities=64512:3000,64512:4000 chain=common-in-client comment="append bgp-community=64512:3000 & 64512:4000, set local-pref=250:" prefix-length=0-24 set-bgp-local-pref=250
