I believe I figured it out and I have the each other’s far-end routes being announced through.
Here is what I did … not 100% sure if this is the correct way, so please comment.
On AS2s edge router, which is the glue between the two peering ASs, I created an aggregate item with a summary of the subnet of AS1 and listed it as “BGP-OUT-FROM-AS1”.
I then when to the BGP peer item for AS3, and put in as the outfilter the “BGP-OUT-FROM-AS1”.
Whol-la .. AS1’s routes are now showing up in the received routes on the AS3 edge router.
Lastly, I reversed the above for the traffic to get back the new path by creating a BGP-OUT-FROM-AS3 and applying that to the peer facing AS1.
Again, I am not 100% if this is the best way to handle this. Thoughts? Comments?
Thanks for the reply Blake. AS1 isn’t directly connected to AS3, so that will work? I obviously have this set on the instance on AS2 as it’s the “man in the middle” - but didn’t think do to this on AS1 or AS3 since they are not direct talkers.
