BGP connection, IP CCR to go out
Hello All,
On CCR I configured a BGP peering connection with 2 multihop remote as using a IP Private and I annunced correctly a /24 Public Subnet. CCR is connected to a BGP peers on eth1 and to LAN on eth3. On the Lan I configured some Private Subnets, using nat rules the subnets go out with a differente Public IPs.
Everything works fine but from CCR I can’t go out (if try from ping tool, when force src address with Public IP works properly). I need to activate some functions on CCR (NTP, log to email), the issue seems on IP address used by CCR to go out, Can I “force” the CCR to use a specific IP for yourself?
IP address scheme:
ETH1 - IP ptp BGP 10.103.11.54/29
ETH1 - Public.1/29 comment=CCR IP address
ETH1 - Public.2/29 comment=IP to masquerade Nat private business customers
ETH1 - Public.3/29 comment=IP to masquerade Nat private residential customers
ETH3 - Private1/22 comment=Subnet business customers
ETH3 - Privare2/22 comment=Subnet residential customers
ETH3 - Public.254/25 comment= Subnet Public IP customers
How I can configure CCR to go out using Public.1/29 ip? Thank you in advance
Kind Regards
Problem is that your CCR only has private IP on interface and every packet you source from CCR will have private address as src-address.
You can solve this by adding src-nat:
ip firewall nat add chain=srcnat action=src-nat src-address=10.103.11.54 out-interface=ether1 to-address=public.1
Also I would suggest not to use masquerade, instead use src-nat for your customers also. And you don’t need to have public.2 and public.3 on ether1 interface (or any other) if you are using them to nat customers.
Thank you for your suggestion.
My fear is that with adding src-nat with Public IP I can’t establish the connection with remote bgp peers (10.103.11.49&50), or am I wrong?
Hmm, yes that would happen. Just add dst-address=!10.103.11.48/30 (or whatever ip of your peer(s) is) to nat rule.
Or you can specify a rule in the srcnat chain which exempts BGP peering:
chain=srcnat protocol=tcp dst-port=179 action=accept
Put this rule early in the srcnat chain, or at least before any rule(s) which would src-nat traffic from the router itself.
