HI All,
After great presentation made by Lorenzo Busatti (Grifonline S.r.l., Italy) I have decided to establish BGP peer with blackhole server with my upstream provider - Cogen.
I made configuration based on their information and now peer is connecting only for milliseconds.
07:27:03 route,bgp,info TCP connection established
07:27:03 route,bgp,info RemoteAddress=130.117.20.1
07:27:03 route,bgp,info Connection terminated
My configuration loos like:
.routing bgp peer
add in-filter=cogent-blackhole-in multihop=yes name=Cogent-BlackHole out-filter=cogent-blackhole-out remote-address=130.117.20.1 remote-as=174 tcp-md5-key=<my-md5-key> ttl=default update-source=<interface-facing-cogent-or-ip-that-was-sent-to-Cogent>
I was playing with that configuration few hours, without luck.
When I remove md5 key from configuration - Cogen will not even respond for my BGP session.
So in my opinion there is fault on their side - or maybe I’m missing something on my side.
That is first configuration with multihop option on my side.
I’m happily using 40 other peers connection - without such issues.
