BGP connections not appearing in sessions
I have a CCR2004-1G-12S+2XS running RouterOS 7.13 with 20 BGP peers running.
Today I added two new ebgp connections (to bring the total to 22), and they just don’t appear in “/routing bgp session” at all. I mean, the issue is not that the sessions aren’t up, but that nothing appears in the menu at all. It’s as if I hadn’t configured them in the first place.
  • these use the same template as other, working sessions. Only the template name, ebgp role, remote IP and ASN is configured for the connections.
  • the remote end is pingable and not multihop
  • there are no Firewall rules
  • reboot doesn’t help
  • nothing appears in the logs about these connections in “bgp” logging, only the “system, info” log lines about me changing the configuration
  • /routing/stats/process/ shows 31 processes, so I thought that perhaps I had hit some kind of a limit. My configuration does not specify any affinities, but I tried one that consolidated things a bit (into 23 processes) — no help.
The relevant config is just:
/routing bgp template
add address-families=ip as=<my asn> comment="Peering v4" disabled=no input.filter=peering_in_v4 name=peering-v4 output.filter-chain=edge_out_v4 .remove-private-as=yes router-id=<my router id> routing-table=main
add address-families=ipv6 as=<my asn> comment="Peering v6" disabled=no input.filter=peering_in_v6 name=peering-v6 output.filter-chain=edge_out_v6 .remove-private-as=yes router-id=<my router id> routing-table=main
/routing bgp connection
add disabled=no local.role=ebgp name=<peer name>-v4 remote.address=<peer ip> .as=<peer asn> templates=peering-v4
add disabled=no local.role=ebgp name=<peer name>-v6 remote.address=<peer ip> .as=<peer asn> templates=peering-v6
Where would you look next?
You have not reached any limits. Check packet sniffer to see if what you have configured actually matches incoming connection.
Thank you, packet sniffer indeed showed connection attempts from my end. So I double checked the config and saw that I was missing a MD5 key… :smiley:
Recapping why I ended up writing to the forum about such a simple config error:
  • I remembered seeing even non-established connections in the Session menu, so I expected this to appear there almost no matter what
  • Absolutely nothing in the logs, not even on the bgp debug level. (Possibly there was something on the packet level but I can’t keep that firehose on)
Thanks again!
had the same issue. also logging with bgp,packet,debug didnt show me a hint why its not working. at the end i have forgotten to configure the md5 password on one of the bgp router… after fixing it, the peer came up under sessions…
