BGP Daemon not listening on IPv6 Addresses
Hi there,
i tried to make a bgp session between two RouterOS (3.28) but it seems that the bgp daemon is not listening on the ipv6 address(es). I get a “Connection refused” when it tries to connect to the neighbor.
Maybe a bug?
Regards,
brainy,
Ensure that you have the ‘routing-test’ 3.28 package installed and that the ‘routing’ 3.28 package is either uninstalled from your router or disabled.
Reboot the router and then try your BGP IPv6 session again…
Regards,
Terry Froy
Spilsby Internet Solutions
