BGP Default Route Problem
could any supporter please tell me, when you wuld fix the, in my opinion major, problem with default routes over bgp?
I tried in 4.10-4.15 but nothing changes.
There are some problems with default route distributed from BGP. We are working on
a new routing package which will fix this problem, but right now if possible do
not distribute BGP default route into OSPF. typically OSPF need to be restarted
(network disable/enable) to make it work again.
> i have an problem with OSPF and BGP.
> I have one router with internet connection. From this router, the
> default route is distributed throug OSPF.
> Then i have a second router that connects this OSPF Area with another.
> Over BGP, a default route is originated for backup. With routing filter,
> i changed BGP route distance to 200.
> First problem, if the default route from BGP is active in OSPF, the
> inter area default route will never come active again.
> Second is, if i deleted BGP default route (routing filter action reject)
> no default route is active in OSPF until reboot of the direct internet
> connected router.
> Any solutions for these problems?
And it’s realy not only a problem with default route.
Greetings
Manuel Ritter
What about this problem? Any solutions until today?
What about the new routing package? When will it be released?
Greetings
Manuel
