I’m sorry, I tried to find this answer on Internet and haven’t found. This is my first expirience with Mikrotik. The RouterOS is great, but… the simple task I can do with other software: I need to delete some communities from prefix in filter. In other words I need cisco like:
route-map rm-bgp-uwes-out permit 1300
match community 30910:1122
set as-path prepend 30910 30910
set comm-list 30910:ALL delete
This should be the equivalent of the cisco filter you posted.
It matches any prefixes with BGP community 30910:1122, and it strips any bgp communities and adds a prepend of 2 (30910 30910).
Your peer(s) should have an Outgoing filter that either jumps to this (rm-bgp-uwes-out) or simply use this one directly (I don’t know what other rules you might have)
Cha0s, your example is good, but not suitable for me. In my example I only need to delete communities started with 30910:, all other communities MUST passthrought
There is no roadmap for v7 - There have been a few teasers posted about it, but Mikrotik has made no announcements regarding an expected release timeframe.
Some people have started to jokingly refer to it as “ROS Longhorn”
