Anybody explane this error
20:39:50 route,bgp,error Terminating connection, too much routes received
20:39:50 route,bgp,error RemoteAddress=10.xx.xx.xxx
20:39:50 route,bgp,error RoutesReceived=1
With BGP, one can filter routes/prefixes by a few different methods.
On of these methods is by limiting the amount of routes (prefixes) a peer can send.
The above error is stating that the other peer is sending more routes than what is configured as amount of routes to be received by your router.
What can i do to prevent this?
Thanks for your reply
Do you have max-prefix-limit set in your BGP config?
that is set to 0
Can you set that to a higher value or just delete it from the configuration and see if that fixes it?
Thanks for repley but i have discover what happend.
I have two routers with the same as, bgp was confused
