Hello Anyone notice that the filter is not working?
/routing filter> export
# sep/06/2011 11:21:17 by RouterOS 5.6
/routing filter
add action=accept chain=isp-1-out disabled=yes invert-match=no prefix=67.55.220.0/24 prefix-length=24
add action=accept chain=isp-1-out disabled=no invert-match=no prefix=67.55.221.0/24 prefix-length=24
add action=accept chain=isp-1-out disabled=yes invert-match=no prefix=67.55.222.0/24 prefix-length=24
add action=accept chain=isp-1-out disabled=yes invert-match=no prefix=67.55.223.0/24 prefix-length=24 set-bgp-prepend=\
10
add action=accept chain=isp-1-out disabled=yes invert-match=no prefix=67.55.224.0/24 prefix-length=24
add action=accept chain=isp-1-out disabled=yes invert-match=no prefix=67.55.225.0/24 prefix-length=24
add action=accept chain=isp-1-out disabled=yes invert-match=no prefix=67.55.226.0/24 prefix-length=24
add action=accept chain=isp-1-out disabled=yes invert-match=no prefix=67.55.227.0/24 prefix-length=24
add action=discard chain=isp-1-out comment=discard disabled=no invert-match=no
add action=discard chain=isp-1-out comment=discard disabled=yes invert-match=no prefix=67.55.220.0/21 prefix-length=\
21-24
add action=discard chain=isp-1-in disabled=no invert-match=no prefix=0.0.0.0
add action=discard chain=isp-1-in disabled=no invert-match=no prefix=67.55.220.0/21 prefix-length=21-24
my rb1100 still getting routing from bgp peer and cpu is 100% all the time finally i manage to re login and disable the peer + reboot the router and it work normally, but i cannot send my prefixes through my isp.
do you guys have a recommendation how to fix this or doing downgrade to 4.17 should be sufficient?
my config is only a slight modification from the bgp example here
http://wiki.mikrotik.com/wiki/Manual:Simple_BGP_Multihoming#Network_Advertisements_and_Routing_Filters
any pointer will be appreciated
thankyou
