Hello!
I have got a trouble. I have my own PI for example 127.127.127.0/24 and ONE UPLINK.
Setting of my Mikrotik a listed below. tell me please why i can not ping my IP addresses from world?
[admin@GW] > routing bgp peer print status
Flags: X - disabled, E - established
0 E name="bgp_westcall" instance=default remote-address=84.52.96.145 remote-as=25408 tcp-md5-key="" nexthop-choice=default
multihop=yes route-reflect=no hold-time=3m ttl=255 in-filter="" out-filter="" address-families=ip
default-originate=never remove-private-as=no as-override=no passive=no use-bfd=no remote-id=109.167.159.127
local-address=84.52.69.146 uptime=28m17s prefix-count=1 updates-sent=2 updates-received=1 withdrawn-sent=0
withdrawn-received=0 remote-hold-time=3m used-hold-time=3m used-keepalive-time=1m refresh-capability=yes
as4-capability=yes state=established
nov/19/2012 13:30:05 by RouterOS 5.20
software id = CFM7-FF9G
/routing bgp instance
set default as=ASNUMBER client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter="" redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing bgp network
add disabled=no network=127.127.127.0/24 synchronize=no
/routing bgp peer
add address-families=ip as-override=no default-originate=never disabled=no
hold-time=3m in-filter="" instance=default multihop=yes name=bgp_westcall
nexthop-choice=default out-filter="" passive=no remote-address=
84.52.69.145 remote-as=25408 remove-private-as=no route-reflect=no
tcp-md5-key="" ttl=255 update-source=84.52.69.146 use-bfd=no
