I’m having an issue in routeros where I’m trying to bring up a second bgp peer. When I enable the second peer that peer establishes for a second then eventually times out with hold timer expires. If I disable the first peer that is receiving 430 routes and enable the second peer it stays up fine with no issues.
It only seems to happen when I have both peers enabled at the same time.
Any idea what would be going on?
I’ve turned off any firewall when this is happening. On both devices.
