BGP Import IP prefixes from main routing table into vrf?
Hello all,
Is it possible to import ip prefixes from main routing table into vrf?
Thanks!
You can use multi-protocol BGP with VPNv4 address family to distribute routes from VRF route tables - not only to other routers, but also to different routing tables in the router itself.
Yes i know that, but how to do it between main routing table and vrf table?
It is possible in Cisco IOS:
http://www.cisco.com/en/US/docs/ios/12_2s/feature/guide/fs_bgivt.html
