BGP IP Issue
I recently setup BGP with a couple ISPs but I am not having any issues on the BGP setup itself, that works perfectly. The issue I am having is I bought a /24 block off an Auction site, since ARIN is no longer giving any out this was my only option, and it seems this block was HEAVILY used, when I go to the connections log there are IPs from everywhere trying to connect to anything and everything.
So my question is, is there a way to setup a script or some sort of filtering to drop or add the source IPs to a blacklist. All of these connections are just constantly in a “Syn Sent” state, I attached a screenshot of a small portion of the connection log, there are many more.
Use firewall with dst-limit and add-to-address-list action.
What would be a safe number to still allow my actual users to get through?
I am running the below rules (this IP block is not being used for live users right now, so every hit is an unwanted IP and my blacklist is already over 1500 entries in the 2 minutes it has been running)
add action=add-src-to-address-list address-list=BLACKLIST address-list-timeout=\
    2w chain=input comment="Rate Limit" dst-address=0.0.0.0/24 dst-limit=\
    10,10,src-address/1m40s protocol=tcp tcp-flags=syn
    2w chain=forward dst-address=0.0.0.0/24 dst-limit=\
Yep, you’ll need new firewall rules at all of your sites who have any public IP address configured.
Yeah, rules for Static IPs are the easy part, the hard part is allowing connectivity for Dynamic IPs and IPs from indirect customers.
Are there no filtering options for connections that are constantly in a “syn sent” state?
