BGP issue upgrading from ROS 6 to ROS 7
Hello !
I’m trying to upgrade one of my border router from OS6 to OS7, but whenever I try to my eBGP session never comes back up.
I’ve added a new filter rule to accept 0.0.0.0/0 already. I still can’t get a default route.
I’m setting the local role in template to bgp customer.
Any ideas on how to solve that?
without your config - it is impossible to advise anything
this is the current one running (and working) on OS6
routing bgp export
jun/06/2024 04:04:25 by RouterOS 6.49.13
software id = B92F-4YQY
model = CCR2004-1G-12S+2XS
serial number = D4F10E985ED6
/routing bgp instance
add as=xxxxx name=american-tower redistribute-connected=yes router-id=1xx.2xx.1xx.77
/routing bgp network
add network=1xx.2xx.1xx.144/29
add network=1xx.2xx.1xx.88/29
add network=2xx.1xx.0.0/29
/routing bgp peer
add in-filter=bgp-in instance=american-tower multihop=yes name=flo remote-address=1xx.2xx.1xx.78 remote-as=xxxxx
tcp-md5-key=🤫 update-source=sfp-sfpplus1
I guess that the problem is update-source. Look what is happening after upgrade, if local-address is empty, then set it to desired IP address.
You can start by checking this article on differences between v6 and v7:
https://help.mikrotik.com/docs/display/ROS/Moving+from+ROSv6+to+v7+with+examples#MovingfromROSv6tov7withexamples-BGPConfiguration
@goldenski,
I haven’t use ROS6 (only 7) with BGP but will try to help.
Please post your routing filters too.
This is your subnets for advertise, right?
and you wand to accept only default route, rigth?
True, when update-source is set to an interface name, the conversion from v6 to v7 fails.
When the IP address on your sfp-sfpplus1 interface is fixed, you can change the update-source to that IP address in v6 and try to convert.
When it is dynamic, well, tough luck. v7 does not support that.
But you can try making update-source empty.
[sigloadmin@NEZA-CORE-2] > routing filter export
jun/07/2024 10:14:53 by RouterOS 6.49.13
/routing filter
add action=discard chain=bgp-in prefix=0.0.0.0/0 prefix-length=0 protocol=bgp
add action=discard chain=ospf-out prefix=8.8.8.8 protocol=ospf
add action=discard chain=ospf-in prefix=1.1.1.1
