Hi guys,
I’ve my own ASN with one transit provider and a local IXP. However, transit bandwidth (or a dedicated connection from my country to a data center in the US) is extremely expensive here, $100+/Mbps, but High Speed cable/FTTH are inexpensive, but have certain limitations, specially that you can’t download more than 10Mbps on a single connection, but if you’ve a download accelerator o multiple downloads you can easily achieve 80+Mbps for less than $300. So, I was thinking of a L2overL3 connection to a data center in the US (that allows us to use BGP), so I was thinking of “bond” multiple cable connections and do a virtual link over Internet.
What do you think about the idea? Any recommendation to achieve the maximum 80+Mbps instead of the 10Mbps of a single connection, multiple VPNs?
Thanks,
