Hi guys.
After applying following doc:
https://wiki.mikrotik.com/wiki/Manual:BGP_Load_Balancing_with_two_interfaces
Im very satsified about it load balancing, it automatically loads 50 % aprox en each link.
Problem is that failover is not working.
After disabling one of both interface traffic goes down and not goes over live link.
btw:
1 I already checked that ping to gateway is not reachable during link down.
2 I also set the check gateway, ping option for that route.
My config lines are very similar to link.
I can share if needed.
Any advice would be great.
Regards.
