Sirrin
February 7, 2011, 2:08pm
1
Hello!
Please help me to adjust load balancing for outgoing traffic.
Have 2 ISP, each of them give us Full View. And have 1 Uplink from both ISP, totally we have 2 uplinks. It is necessary to adjust mikrotik so that the proceeding traffic was distributed between two uplinks in regular intervals, or almost in regular intervals.
ROS v5.0rc8 on x86
set default as=9177 client-to-client-reflection=no disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no \
redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=82.200.96.130 routing-table=""
add as=9177 client-to-client-reflection=no disabled=no ignore-as-path-len=no name=ZAO_KES out-filter="" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no \
redistribute-rip=no redistribute-static=no router-id=62.32.76.85 routing-table=""
/routing bgp network
add disabled=no network=81.161.208.0/20 synchronize=no
add disabled=no network=193.169.60.0/23 synchronize=no
add disabled=no network=46.172.96.0/19 synchronize=no
/routing bgp peer
add address-families=ip as-override=no default-originate=never disabled=no hold-time=3m in-filter=ZSTTK_Weight instance=default multihop=no name=ZSTTK nexthop-choice=default \
out-filter=ZSTTK_Prepend passive=no remote-address=82.200.96.129 remote-as=21127 remove-private-as=no route-reflect=no tcp-md5-key="" ttl=default use-bfd=no
add address-families=ip as-override=no default-originate=never disabled=no hold-time=3m in-filter=ZAO_KES_Weight instance=ZAO_KES multihop=no name=ZAO_KES nexthop-choice=\
default out-filter=ZAO_KES_Prepend passive=no remote-address=62.32.76.85 remote-as=44436 remove-private-as=no route-reflect=no tcp-md5-key="" ttl=default use-bfd=no
/routing filter
add action=passthrough chain=bgp-out disabled=yes invert-match=no set-bgp-local-pref=122 set-bgp-prepend=3
add action=passthrough chain=ZSTTK_Prepend disabled=no invert-match=no prefix=0.0.0.0
add action=passthrough chain=ZAO_KES_Prepend disabled=no invert-match=no prefix=0.0.0.0 set-bgp-prepend=15
mrz
February 7, 2011, 2:19pm
2
Adjust bgp weight so that half of the routes are routed over one peer and other half over another.
Sirrin
February 8, 2011, 3:34am
3
But i have 3 nets, and i can use 2 filter on peer. Maybe i don’t unerstand where this is doing? Can you be so kind as to show me an example of config?
Hello Sirrin,
I’m also to do BGP Load Balancing with 2ISP and single BGP but is not working.
Other way we need BGP two:
BGP1 peering to ISP1
BGP2 peering to ISP2
I try this way is working.
configure: BGP1 peering to ISP1
/routing bgp instance
set default as=9177 client-to-client-reflection=yes disabled=no ignore-as-path-len=no name=default out-filter=“” redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing bgp peer
add address-families=ip as-override=no default-originate=never disabled=no hold-time=3m in-filter=“” instance=default multihop=yes name=isp1 nexthop-choice=default out-filter=isp1-out passive=no remote-address=82.200.96.129 remote-as=21127 remove-private-as=no route-reflect=no tcp-md5-key= ttl=default use-bfd=no
add disabled=no network=46.172.96.0/19 synchronize=yes
/routing filter
add action=accept chain=isp1-out disabled=no invert-match=no prefix=81.161.208.0/20
add action=accept chain=isp1-out disabled=no invert-match=no prefix=193.169.60.0/23
add action=accept chain=isp1-out comment=“Accept our networks and prepend AS path three times” disabled=no invert-match=no prefix=46.172.96.0/19 set-bgp-prepend=3
add action=discard chain=isp1-out-out comment=“discard the rest” disabled=no invert-match=no
configure: BGP2 peering to ISP2
/routing bgp peer
add address-families=ip as-override=no default-originate=never disabled=no hold-time=3m in-filter=“” instance=default multihop=yes name=isp2 nexthop-choice=default out-filter=isp2-out passive=no remote-address=62.32.76.85 remote-as=44436 remove-private-as=no route-reflect=no tcp-md5-key= ttl=default use-bfd=no
add disabled=no network=81.161.208.0/20 synchronize=yes
add disabled=no network=193.169.60.0/23 synchronize=yes
/routing filter
add action=accept chain=isp2-out comment=“Accept our networks and prepend AS path three times” disabled=no invert-match=no prefix=81.161.208.0/20 set-bgp-prepend=3
add action=accept chain=isp2-out comment=“Accept our networks and prepend AS path three times” disabled=no invert-match=no prefix=193.169.60.0/23 set-bgp-prepend=3
add action=accept chain=isp2-out disabled=no invert-match=no prefix=46.172.96.0/19
add action=discard chain=isp2-out-out comment=“discard the rest” disabled=no invert-match=no
I want to do single bgp with multi-home. I do follow (http://wiki.mikrotik.com/wiki/Manual:Simple_BGP_Multihoming ) on Load sharing setup not failed over
what mistake please help?
