Hello
I have this setup
http://wiki.mikrotik.com/wiki/Manual:Simple_BGP_Multihoming#Load_sharing_setup
But problem is that, router is using one link only fordownload nad an other for upload, can i configure so to use both links for upload and download?
Thank you
so you have bgp peering to both your ISP’s?
look into ECMPR and so forth,
http://wiki.mikrotik.com/wiki/PCC#Policy_routing to track connections the same way as they come in, then just iether Nth them out or balance them with ECMPR
Thank you for helping.
But i dont know destionation address, i have 400000 prefix recordes in ruting table.
I am receiving prefixis for over the world from two isp.
Hello
Please may be someone can help me,
I have installed this to bgp to seperate mikrotiks, on rotuer 1 and router 2
then i have pppoe server with 2000 customers on router 3, router 3 gateway is router 1 (routing mark half network) another gateway router 2 (ruting mark left half network)
Problem is that, traffic is going from router 1 and coming from router 2.
Can anyone help me?
Thank you
I do not believe that BGP load balancing, nor BGP summaries is supported.
You need to increase your distance on the route that traffic is going too, that way the outbound traffic goes out the in interface. There are multiple techniques available for load balancing. Here is one:
