What’s mean this log ?:
10:11:09 route,bgp,info Failed to open TCP connection: Operation now in progress
10:11:09 route,bgp,info RemoteAddr=PEER_ADDRESS
10:11:09 route,bgp,info RemotePort=179
Thanks .-
Thanks .-
without seeing more of the log I am guessing tcp/179 is not allowed between the peers, or the remote peer is not allowing you to connect. Sometimes you will see 5-10 of those though and it will then connect up fine later.
Sam
Changeip, the bgp peer is active …
Into Remote Peer:
#sh ip bgp sum
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
Mk_IP 4 #### 187515 235740 888338 0 0 4w5d 24
This is a Cisco Router and debugging don’t have any log about BGP errors or not connections.
