BGP MED Attribute and IBGP
I am a little bit confused with Mikrotik’s BGP MED attribute implementation.
Two observations from the LAB (tested both v5.24 and v6.0rc11):
  1. MED works ok for EBGP sessions. But when propagating external routes to internal BGP (IBGP) neighbors, MED attributes are deleted.
  2. When a Mikrotik router receives the same route from an EBGP neighbor and from an IBGP neighbor ( Cisco, by example, propagates MED attr. over IBGP sessions), MED values are not evaluated as part of the BGP best route selection process.
    Are these observations correct ?
    Is this the way MED is implemented in RouterOS’s BGP ?
From the manual:
http://wiki.mikrotik.com/wiki/Manual:BGP_Best_Path_Selection_Algorithm
The router compare MED attribute only for paths that have the same neighboring (leftmost) AS. Paths without explicit MED value are treated as with MED of 0
Thank you for your quick response but let me explain my question with more detail.
Imagine this scenario with 2 routers (R1 & R2) in AS65001 and another 2 (R3 & R4) in AS65002:
R1[AS65001] ------- R3[AS65002]------R4[AS65002]---------R2[AS65001]
R1 announces a route to 10.10.12.0/24 to R3 with MED=101
R2 announces same route to R4 with MED=102
  1. If R4 is a Mikrotik router it receives the route correctly form R2 with MED=102
    but when propagating it to it’s IBGP peer R3 it sends it with MED=0
[admin@R4] > /routing bgp advertisements print R3 detail
 peer="R3" prefix=10.10.12.0/24 nexthop=10.10.34.4 as-path="65001"
   origin=incomplete local-pref=100
  1. And if R3 is a router that propagates MED to IBGP peers (as Cisco or Juniper do) at R4 we have 2 routes to 10.10.12.0/24
    both with the same:
  • Weight
  • Local Pref
  • AS Path
  • Origin
[admin@R4] > /ip route print detail
0 ADb  dst-address=10.10.12.0/24 gateway=10.10.24.2
        gateway-status=10.10.24.2 reachable via  ether2 distance=20 scope=40
        target-scope=10 bgp-as-path="65001" bgp-med=102 bgp-origin=incomplete
        received-from=R2
 1  Db  dst-address=10.10.12.0/24 gateway=10.10.34.3
        gateway-status=10.10.34.3 reachable via  ether3 distance=200 scope=40
        target-scope=30 bgp-as-path="65001" bgp-local-pref=100 bgp-med=101
        bgp-origin=incomplete received-from=R3
Then, according to http://wiki.mikrotik.com/wiki/Manual:BGP_Best_Path_Selection_Algorithm, MED should be compared and route 1 with MED=101 selected as best. But our LAB shows thar route 0 with MED=102 is the active route.
From 1) and 2) it looks like MED in Mikrotik is used only in EBGP: It is not propagated to IBGP peers and it’s value is ignored when a route from an IBGP peer is one of the candidates.
I’d like to know if this is a design decision in RouterOS or a bug.
MED will not be used for routes received from iBGP peer.
OK. Not a bug then.
RFC4451 writes only a “MAY” on that but it will be great if MED could be propagated and used also in iBGP.
Thank you.
Best Regards.
