Hi All,
Have spent the last week playing in a lab setup for a deployment I am planning. I have created the lab in the basic sense of four nodes connected in a ring. My issue arises when I pass a customer VRF Site 1 > Site 2 the network functions correctly via the shortest/direct connected path however if I break this path the sites connectivity never recover.
BGP sessions are established between each node to a /32 loopback with static routes for each leg.
Topology:
Configurations:
Brisbane-1
add fast-forward=no name=lo1
add name=dhcp_pool0 ranges=10.0.0.2-10.0.0.254
add address-pool=dhcp_pool0 disabled=no interface=ether4 name=dhcp1
/routing bgp instance
add as=1234 name=ISP-Name redistribute-connected=yes redistribute-other-bgp=yes redistribute-static=yes \
router-id=172.16.0.1
/routing ospf instance
set [ find default=yes ] disabled=yes router-id=172.16.0.1
add address=192.168.10.1/30 interface=ether1 network=192.168.10.0
add address=192.168.40.2/30 interface=ether2 network=192.168.40.0
add address=172.16.0.1 interface=lo1 network=172.16.0.1
add address=10.0.0.1/24 interface=ether4 network=10.0.0.0
/ip dhcp-client
add disabled=no interface=ether1
add dhcp-options=hostname,clientid disabled=no interface=ether5
add address=10.0.0.0/24 gateway=10.0.0.1
add action=masquerade chain=srcnat out-interface=ether5
add distance=1 dst-address=172.16.0.2/32 gateway=192.168.10.2
add distance=1 dst-address=172.16.0.4/32 gateway=192.168.40.1
/ip route vrf
add export-route-targets=0:1 import-route-targets=0:1 route-distinguisher=0:1 routing-mark=vrf-customer
/mpls
set propagate-ttl=no
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=172.16.0.1 transport-address=172.16.0.1
/mpls ldp interface
add interface=ether1
add interface=ether2
/routing bgp instance vrf
add instance=ISP-Name redistribute-connected=yes redistribute-ospf=yes redistribute-other-bgp=yes \
redistribute-rip=yes redistribute-static=yes routing-mark=vrf-customer
/routing bgp peer
add address-families=ip,ipv6,l2vpn,l2vpn-cisco,vpnv4 default-originate=always instance=ISP-Name name=peer1 \
remote-address=192.168.10.2 remote-as=1234 route-reflect=yes update-source=ether1
add address-families=ip,ipv6,l2vpn,l2vpn-cisco,vpnv4 default-originate=always instance=ISP-Name name=peer2 \
remote-address=192.168.40.1 remote-as=1234 route-reflect=yes update-source=ether2
/system identity
set name=BNE1
Brisbane-2
add name=lo1
add name=dhcp_pool0 ranges=192.168.101.2-192.168.101.254
add address-pool=dhcp_pool0 disabled=no interface=ether5 name=dhcp1
set default disabled=yes
add as=1234 name=ISP-Name redistribute-connected=yes redistribute-other-bgp=\
yes redistribute-static=yes router-id=172.16.0.4
set [ find default=yes ] router-id=172.16.0.4
add address=192.168.101.1/24 interface=ether5 network=192.168.101.0
add address=192.168.30.1/30 interface=ether2 network=192.168.30.0
add address=192.168.40.1/30 interface=ether1 network=192.168.40.0
add address=172.16.0.4 interface=lo1 network=172.16.0.4
/ip dhcp-client
add address=192.168.101.0/24 dns-server=1.1.1.1 gateway=192.168.101.1
add distance=1 dst-address=172.16.0.1/32 gateway=192.168.40.2
add distance=1 dst-address=172.16.0.3/32 gateway=192.168.30.2
/ip route vrf
add export-route-targets=0:1 import-route-targets=0:1 interfaces=ether5 \
/mpls
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=172.16.0.4 transport-address=\
172.16.0.4
/mpls ldp interface
add instance=ISP-Name redistribute-connected=yes redistribute-ospf=yes \
redistribute-other-bgp=yes redistribute-rip=yes redistribute-static=yes \
/routing bgp peer
add address-families=ip,ipv6,l2vpn,l2vpn-cisco,vpnv4 instance=ISP-Name name=\
peer1 remote-address=192.168.30.2 remote-as=1234 route-reflect=yes \
peer2 remote-address=192.168.40.2 remote-as=1234 route-reflect=yes \
/system identity
set name=BNE-2
Perth-1
add name=lo1
router-id=172.16.0.2
set [ find default=yes ] router-id=172.16.0.2
add address=192.168.10.2/30 interface=ether2 network=192.168.10.0
add address=192.168.20.1/30 interface=ether1 network=192.168.20.0
add address=172.16.0.2 interface=lo1 network=172.16.0.2
/ip dhcp-client
add distance=1 dst-address=172.16.0.1/32 gateway=192.168.10.1
add distance=1 dst-address=172.16.0.3/32 gateway=192.168.20.2
/ip route vrf
/mpls
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=172.16.0.2 transport-address=172.16.0.2
/mpls ldp interface
/routing bgp peer
remote-address=192.168.20.2 remote-as=1234 route-reflect=yes update-source=ether1
add address-families=ip,ipv6,l2vpn,l2vpn-cisco,vpnv4 default-originate=if-installed instance=ISP-Name name=\
peer2 remote-address=192.168.10.1 remote-as=1234 route-reflect=yes update-source=ether2
/system identity
set name=Perth-1
Perth 2
add name=lo1
add name=dhcp_pool0 ranges=192.168.8.2-192.168.8.254
yes redistribute-static=yes router-id=172.16.0.3
set [ find default=yes ] router-id=172.16.0.3
add address=192.168.8.1/24 interface=ether5 network=192.168.8.0
add address=192.168.30.2/30 interface=ether1 network=192.168.30.0
add address=192.168.20.2/30 interface=ether2 network=192.168.20.0
add address=172.16.0.3 interface=lo1 network=172.16.0.3
/ip dhcp-client
add address=192.168.8.0/24 dns-server=1.1.1.1 gateway=192.168.8.1
add distance=1 dst-address=172.16.0.2/32 gateway=192.168.20.1
add distance=1 dst-address=172.16.0.4/32 gateway=192.168.30.1
/ip route vrf
/mpls
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=172.16.0.3 transport-address=\
172.16.0.3
/mpls ldp interface
/routing bgp peer
add address-families=ip,ipv6,l2vpn,l2vpn-cisco,vpnv4 default-originate=\
if-installed instance=ISP-Name name=peer1 remote-address=192.168.20.1 \
if-installed instance=ISP-Name name=peer2 remote-address=192.168.30.1 \
/system identity
set name=Perth-2
Any assistance is appreciated.
