I have (A) edge routing peering service provider using AS 1111 (Default Instance), On the other hand I have the same (A) (AS 22222) edge routing peering (B) (AS 3333) internal router using eBGP on different Instance, However routes are being advertised to both external and internal peer. How can I make routes be advertised only to internal peers?
running two different instances wouldn’t allow me to run separate BGP processes with different configurations and peerings? why routes are still being advertised to both peers?
thanks, I got your point, but take a look at this ss, two instances, 4 neighbors. 3 of them in the same instance nevertheless the publix prefix is advertised to VA , NGN , CASTRO and SILICA neighbors.
How do I declare one network belongs to one instance?
