Hello, I Seek the forum and found nothing that clears my doubt.
So here is:
I have a FreeBSD BGP (Zebra+Quagga) running, and I want to change to a Mikrotik BGP.
In the FreeBGP, I have 2 instances, 2 different AS's
So all I needed to do was declare multiple-instance, and for the second AS, i declared as a 'view'.
In mikrotik, I heard that I can do multiple instance too, but I didn't figured how.
I did:
[admin@MikroTik] > routing bgp instance print
Flags: X - disabled
0 name="default" as=65530 router-id=0.0.0.0 redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter="" client-to-client-reflection=yes
ignore-as-path-len=no routing-table=""
1 name="INSTANCE_1" as=MY_AS_1 router-id=MY_ROUTER_ID_1 redistribute-connected=yes
redistribute-static=yes redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter="" client-to-client-reflection=no
2 name="INSTANCE_2" as=MY_AS_2 router-id=MY_ROUTER_ID_2 redistribute-connected=yes
[admin@MikroTik] > routing bgp peer print
Flags: X - disabled, E - established
INSTANCE.....................REMOTE-ADDRESS.............................................REMOTE-AS
0 INSTANCE_1...................REMOTE_ADDRESS_OF_MY_LINK_PROVIDER............AS_OF_MY_LINK_PROVIDER
But I can't add another Peer, for the INSTANCE_2, is that needed?
Thanks, and sorry for any English mistake, hehe ![]()
