BGP networks limit to 200
Hi All!
I have RB2011LS:
  • RouterOS v6.7
  • current-firmware: 3.10
I run a BGP session and want to pass about 800 networks from RB2011 to ASR1002 with /32 mask.
Then i try do it, the routerboard annonce only 200 networks and generates error - “failure: number of BGP networks is limited to 200”.
Please tell me - is there any way to get around this limitation?
P.S. Aggregation offer not need.
Typically you add to networks your whole prefix range. And in most cases you do not own 200 different prefixes.
Another way is to advertise routes from routing table (add static unreachable routes and set redistribute-static in instance settings)
