BGP networks limit to 200
Hi All!
I have RB2011LS:
  • RouterOS v6.7
  • current-firmware: 3.10
I run a BGP session and want to pass about 800 networks from RB2011 to ASR1002 with /32 mask.
Then i try do it, the routerboard annonce only 200 networks and generates error - “failure: number of BGP networks is limited to 200”.
Please tell me - is there any way to get around this limitation?
P.S. Aggregation offer not need.
I thought the only solution to your problem is that you have to replace your router to some higher versions that allows as many networks as you needed.
Post your bgp config , both sides, Routerboard as well as Cisco… chances are that you have Max Prefix limit defined as 200…
Thank you for your replyes.
Solved the problem of prescription static routes.
