BGP not announcing IPs using small CIDR
Hi guys,
I’ve some public /24 using BGP and they’re announced properly, I’ve filters to send only certain CIDRs and block everything else, synchronize Networks is enabled.
Now I’m trying to create a small PtP using /30 public IP address (between the BGP router and the other router), I also created all the other networks to complete the /24, then add the filter to enable that CIDR and prefix-length 24-32. I tried to enable the networks x.x.x.x/24 and synchronize and didn’t work, then I tried using Aggregate and enabled summarize and specified x.x.x.x/24 but didn’t work, any idea?
Thanks,
to figure out this, you have to post some config.
