BGP on Mikrotik
hello all,
We were looking ahead to implement BGP in our network, we have level 5 licence on our Mikrotik router. we are taking BGP for multi-homing with multiple ISPs over Internet.
I would like to know, if mikrotik can perform well with it and what things should taken care of before implementing BGP over mikrotik. How sucessfull it is till date.
THank
Binayak
Leaving out some hickups that appear know and then.. it works OK. Not as good as quagga or cisco IOS but its OKish.
We have been using it in our community for almost 2 years know. :slight_smile:
Do you use it for public IP ranges?
Is it stable?
Anybody who can comment if use BGP for public IPs ?
We are trying to set-up a new Internet Exchange in Malawi and we have worked out a router configuration using cisco bgp 4 as shown below. Now some us want to use Mikrotik router on the RB532 board and we are wondering how to convert our worked out cisco config to a corresponding mikrotik config.
  • Could anyone please show us how to do a “peer-group” as done on the cisco config below?
  • how do we do a corresponding router-map?
  • what is the corresponding filter specification?
thanks in advance
Router> enable
Router# config terminal
Router(config)# hostname ISPA
ISPA(config)# no ip domain-lookup
ISPA(config)#interface loopback 0
ISPA(config-if)#ip address 172.30.0.7 255.255.255.255
ISPA(config)#interface Ethernet0
ISPA(config-if)# ip address 172.30.1.7 255.255.255.0
ISPA(config-if)#no shutdown
! will be replaced by our wlan interface on mikrotik
ISPA(config)#interface Serial1
ISPA(config-if)# ip address 192.168.0.1 255.255.255.0
ISPA(config-if)# clockrate 64000
ISPA(config-if)# no shutdown
ISPA(config)#router bgp 33773
ISPA(config-router)# no synchronization
ISPA(config-router)# no auto-summary
ISPA(config-router)#bgp log-neighbor-changes
ISPA(config-router)#network 196.45.188.0 mask 255.255.252.0
ISPA(config-router)#network 198.32.68.0 mask 255.255.255.0
ISPA(config-router)#neighbor IXP-peers peer-group
ISPA(config-router)#neighbor IXP-peers password sameforallpeers
ISPA(config-router)#neighbor IXP-Peers send-community
ISPA(config-router)#neighbor IXP-Peers version 4
ISPA(config-router)#neighbor IXP-Peers soft-reconfiguration inbound
ISPA(config-router)#neighbor IXP-Peers ebgp-multihop 3
ISPA(config-router)#neighbor 172.30.0.1 remote-as 65501
ISPA(config-router)#neighbor 172.30.0.1 update-source loopback 0
ISPA(config-router)#neighbor 172.30.0.1 description EBGP with Burco
ISPA(config-router)#neighbor 172.30.0.1 peer-group IXP-peers
ISPA(config-router)#neighbor 172.30.0.2 remote-as 65502
ISPA(config-router)#neighbor 172.30.0.2 update-source loopback 0
ISPA(config-router)#neighbor 172.30.0.2 description EBGP with CoM
ISPA(config-router)#neighbor 172.30.0.2 peer-group IXP-peers
ISPA(config-router)#neighbor 172.30.0.3 remote-as 65503
ISPA(config-router)#neighbor 172.30.0.3 update-source loopback 0
ISPA(config-router)#neighbor 172.30.0.3 description EBGP with Skyband
ISPA(config-router)#neighbor 172.30.0.3 peer-group IXP-peers
ISPA(config-router)#neighbor 172.30.0.4 remote-as 65504
ISPA(config-router)#neighbor 172.30.0.4 update-source loopback 0
ISPA(config-router)#neighbor 172.30.0.4 description EBGP with CompLand
ISPA(config-router)#neighbor 172.30.0.4 peer-group IXP-peers
ISPA(config-router)#neighbor IXP-Peers route-map Net-No-Export out
ISPA(config)#route-map Net-No-Export permit 10
ISPA(config-route-map)set community no-export
ISPA(config)#route-map Net-No-Export permit 20
ISPA(config-router)#neighbor 172.30.0.1 maximum-prefix 100
ISPA(config-router)#neighbor 172.30.0.2 maximum-prefix 100
ISPA(config-router)#neighbor 172.30.0.3 maximum-prefix 100
ISPA(config-router)#neighbor 172.30.0.4 maximum-prefix 100
ISPA(config-router)#neighbor IXP-peers filter-list 1 out
ISPA(config-router)#neighbor IXP-peers filter-list 2 in
ISPA(config-router)#ip as-path access-list 1 permit ^$
ISPA(config-router)#ip as-path access-list 2 permit ^(65501|65502|65503|65504)$
ISPA(config-router)#neighbor IXP-peers prefix-list out-nets out
ISPA(config-router)#neighbor IXP-peers prefix-list in-nets in
ISPA(config)#ip prefix-list in-nets seq 5 permit 172.30.0.0/30 le 32
ISPA(config)#ip prefix-list in-nets seq 10 permit 172.30.1.0/24
ISPA(config)#ip prefix-list in-nets seq 20 deny 10.0.0.0 /8 le 32
ISPA(config)#ip prefix-list in-nets seq 25 deny 172.16.0.0/12 le 32
ISPA(config)#ip prefix-list in-nets seq 30 deny 192.168.0.0/16 le 32
ISPA(config)#ip prefix-list in-nets seq 35 permit 0.0.0.0/0 le 32
ISPA(config)#ip prefix-list out-nets seq 5 permit 172.30.0.0/30 le 32
ISPA(config)#ip prefix-list out-nets seq 10 permit 172.30.1.0/24
ISPA(config)#ip prefix-list out-nets seq 20 deny 10.0.0.0 /8 le 32
ISPA(config)#ip prefix-list out-nets seq 25 deny 172.16.0.0/12 le 32
ISPA(config)#ip prefix-list out-nets seq 30 deny 192.168.0.0/16 le 32
ISPA(config)#ip prefix-list out-nets seq 35 permit 0.0.0.0/0 le 32
ISPA(config)#ip route 172.30.0.1 255.255.255.255 172.30.1.1
ISPA(config)#ip route 172.30.0.2 255.255.255.255 172.30.1.2
ISPA(config)#ip route 172.30.0.3 255.255.255.255 172.30.1.3
ISPA(config)#ip route 172.30.0.4 255.255.255.255 172.30.1.4
! If you can’t see your own networks in your BGP table, add:
ISPA(config)#ip route 196.45.188.0 255.255.252.0 null0
ISPA(config)#ip route 194.42.96.224 255.255.255.240 null0
ISPA(config)#ip route 198.32.68.0 255.255.255.0 null0
