Good morning everyone,
I would like to share with you a problem that I am having with BGP.
The actual situation:
- SiteB and SiteC connect to Site A (main site) with WireGuard.
- Configured BGP well in 3 sites and in all the routes are propagated without any problem.
- All sites use mark-routing to use Wireguard connection. At this point the default gw in each site is 0.0.0.0/0 across the Wireguard Tunnel and Wireguard Table that I created. ALL TRAFFIC goes perfectly to main site (SiteA) and exit to Internet by default gw.
The new situation:
- In BGP I enabled that propagate source origin and showed well the new default gw in the SiteB and SIteC (appears in main table).
- The SiteB and SiteC goes to Internet across their default gw (their router) instead go to siteA and exit from it default gateway.
The default gw to Internet have distance 2.
The default gw to Internet across BGP is 200.
If I remove the default local gw. I lost all access, so it’s necessary.
I know that I need to play with mark-routes but I can’t found any solution. Any ideas to solve it?
Best regards!
