Hi guys,
I have a setup with one BGP instance and 2 peers. One peer has max prefixes limitation, and the other one advertises 15k prefixes.
Both peers work fine separately. However the limiting peer doesn’t connect if the beefy one is connected - this is how I knew about the prefix limiting. So I added an out-filter to the peer to filter just 2 prefixes that are needed for that peer, and still it doesn’t connect.
Does that mean that filter does not reduce the number of negotiated prefixes?
