BGP Peer to only advertise default gateway
Good day
I have a issue where I have a peer configured to send out a default gateway.
add default-originate=always name=Default-GW-Advertise remote-address=xxx.xxx.xxx.xxx remote-as=200 ttl=default
But due to me not having any Out-Filter I am advertising my whole routing table to the remote peer and that is not correct.
All I want to advertise is the Default-GW.
How should I create my Out-Filter. Also I am not going to receive anything from the remote peer.
Regards
Be sure that your instance has:
  • redistribute-connected: no
  • redistribute-ospf: no
  • redistribute-other-bgp: no
  • redistribute-rip: no
  • redistribute-static: no
  • client-to-client-reflection: no
And you will have no need to use any filter.
If this doesn’ work, please export here your BGP configuration for both Peer.
