I just installed routing-test package to my both mikrotiks. I just want to set up a simple BGP peer along them.
Mikrotik 1:
/routing bgp instance set default as=65001 router-id=a.b.c.1 redistribute-static=yes
/routing bgp peer add name=peer1 remote-address=a.b.c.2 remote-as=65002
Mikrotik 2:
/routing bgp instance set default as=65002 router-id=a.b.c.2 redistribute-static=yes
/routing bgp peer add name=peer1 remote-address=a.b.c.1 remote-as=65001
but peer state is always “connect” I think it should be “established” or something like that. Also, I cannot see the remote AS and remote router ID properties on peer property pages.
Any comments?
Thank you very much!
