I have 2 ISPs connected to a Mikrotik Router which I am using for BGP. In Winbox, how can I force all traffic to go to a specific ISP ? If I simply pull the plug on the one I don’t want, everything stops working. So I assume I have something setup wrong…Any help would be appreciated. Please remember, I use Winbox, I am not familiar with the Router OS Command Line.
You can add an additional 0.0.0.0/0 route with a distance of 2 to the second isps network, or setup ecmp gateways. Use check-gateway=arp if you want to automatically remove that route when its unreachable.
and your advetising this tou level3 only OR to the other provider as well ?
This makes level3 appear further away so your other provider will become the preferred for incoming correct?
Yes, for one of our /24s we annouce out both peers we want most of the traffic to come in Cogent… so the level3 path is prepended to make it look less preferrable.
I did this it has no effect . Want to do exactly the same that you have done to have certain / all classes incoming via a partciular . What I have done is advertised out those classes out to the one I dont want to have incoming from – yipes . But has no effect on the incoming so far. Looked through the looking glass i dont see anything. How do i check or do i prepend further away (more than 2) ?
Sam, have you tried any other version that have been stable for extended time periods? I’m going to be implementing a MikroTik along side of my existing Cisco for BGP (each running eBGP to upstream providers, and iBGP between each other for true failover and redundancy)
I don’t have a copy of the x86 2.9.26 package, and I really don’t want to load a version that hasn’t yet proved it’s stability with BGP.
