I have a BGP session with Team Cymru on a Cisco router and I want to redistribute this bogons from this router to another Mikrotik Routers.
I configured the BGP session on the first MT and all works fine but in the second MT router the bogon prefixes are in invalid state, same configuration, same RouterOS Version 3.16, same hardware.
Someone had the same problem?
Thanks in advance,
Pablo
i attempted to do the same thing, although i was marking the routes coming in from cymru in a routing-mark so it didn’t interfere with my main table. i wasn’t able to bgp prefixes in alternate tables I believe. If the routes are just invalid it’s most likely because the gateway isn’t reachable, you might need to set-nexthop using routing-filters.
Invalid or Unreachable? it might be a scope/target-scope problem
here’s a config example from team cymru’s website.
# Config by Ariel S. Weher, based on Team Cymru's Cisco Template.
# Working in the 3.X version of Mikrotik RouterOS.
/routing bgp instance
set default as=<YOUR_ASN_NUMBER> client-to-client-reflection=yes comment="" disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=<Your router-id ip address>
/ip firewall address-list
add address=<SESSION#1.Team-Cymru's.IP.Address> comment="TEAM-CYMRU BOGON Server #1" disabled=no list=BGP-NEIGHBORS
add address=<SESSION#2.Team-Cymru's.IP.Address> comment="TEAM-CYMRU BOGON Server #2" disabled=no list=BGP-NEIGHBORS
add action=accept chain=input comment="BGP Neighbors" disabled=no dst-port=179 protocol=\
tcp src-address-list=BGP-NEIGHBORS
add comment="Blackhole traffic route" disabled=no distance=1 dst-address=192.0.2.1/32 type=blackhole
/routing bgp peer
add address-families=ip comment="TEAM-CYMRU BOGON Server #1" disabled=no hold-time=3m in-filter=BOGON-SERVER-IN \
instance=default max-prefix-limit=50 multihop=yes name=CYMRU-1 \
nexthop-choice=default out-filter=BGP-DROP remote-address=\
<SESSION#1.Team-Cymru's.IP.Address> remote-as=65333 route-reflect=no tcp-md5-key=Password_Received_From_Cymru ttl=255
add address-families=ip comment="TEAM-CYMRU BOGON Server #2" disabled=no hold-time=3m in-filter=BOGON-SERVER-IN \
<SESSION#2.Team-Cymru's.IP.Address> remote-as=65333 route-reflect=no tcp-md5-key=Password_Received_From_Cymru ttl=255
/routing filter
add action=accept bgp-communities=65333:888 chain=BOGON-SERVER-IN comment="" \
disabled=no invert-match=no protocol=bgp set-out-nexthop=192.0.2.1
add action=discard chain=BOGON-SERVER-IN comment="" disabled=no invert-match=\
no protocol=bgp
add action=discard chain=BGP-DROP comment="" disabled=no invert-match=no \
protocol=bgp
Changeip: next-hop from v3.x was removed, that’s work fine in 2.9.51
Medianet: I mean Unreachable and I using target-scope=40 in both routers
As far as i can see you have multihop peerings, try to lower the scope of your static route to the peer:
Static route scope < BGP route target-scope to make them active
Doesn’t work changing static route scope lower than BGP Target Scope
Any ideas?
Thanks!
Pablo
so the next hop is unreachable? and it’s in a connected route ?
Next hop is 192.0.2.1, these route was created on MT as blackhole interface like null interface in Cisco.
Here’s the export of BGP:
set default as=65503 client-to-client-reflection=yes comment=“” disabled=no ignore-as-path-len=no name=default out-filter=“” redistribute-connected=no
redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=172.16.16.18
/routing bgp peer
add address-families=ip comment=“” disabled=no hold-time=3m in-filter=bogon-in instance=default multihop=yes name=peer1 nexthop-choice=default out-filter=
deny-all remote-address=200.xxx.xxx.xxx remote-as=27926 route-reflect=no tcp-md5-key=nnnnnnn ttl=40
/routing filter
add action=accept bgp-communities=27926:8888 bgp-origin=igp chain=bogon-in comment=“” disabled=no invert-match=no protocol=bgp set-out-nexthop=192.0.2.1
set-target-scope=40
add action=discard bgp-origin=“” chain=bogon-in comment=“” disabled=no invert-match=no protocol=bgp
add action=discard chain=deny-all comment=“” disabled=no invert-match=no
add comment=“” disabled=no distance=1 dst-address=192.0.2.1/32 type=blackhole
Regards,
Pablo
Is that 192.0.2.1 active in the routing table? Can you run an /ip route print detail and give me that snippet ?
Also, just for troubleshooting, try creating an empty bridge interface (loopback), and place the 192.0.2.1/32 IP address on it… and remove the blackhole rule. I am wondering if it’s the blackhole feature that’s causing it to be unreachable, since it’s a blackhole.
Hello Changeip, here is a part of my routing table, as you can see static route is already active.
36 Db 175.0.0.0/8 unreachable 192.0.2.1 20
37 Db 176.0.0.0/8 unreachable 192.0.2.1 20
38 Db 177.0.0.0/8 unreachable 192.0.2.1 20
39 Db 179.0.0.0/8 unreachable 192.0.2.1 20
40 Db 180.0.0.0/8 unreachable 192.0.2.1 20
41 Db 181.0.0.0/8 unreachable 192.0.2.1 20
42 Db 182.0.0.0/8 unreachable 192.0.2.1 20
43 Db 183.0.0.0/8 unreachable 192.0.2.1 20
44 Db 185.0.0.0/8 unreachable 192.0.2.1 20
45 Db 192.0.2.0/24 unreachable 192.0.2.1 20
46 A SB 192.0.2.1/32 1
Creating an empty bridge with ip address 192.10.2.1/32 works fine because I tried before but why don’t with blackhole interface? In other hand I have a similiar router with same configuration without problems.
Thanks!
Pablo
I have same problem. Static ip address on a bridge interface doesn’t resolve problem.
IP prefixes received from Cymru’s bogon servers are inactive.
0 Db dst-address=1.0.0.0/8 gateway=192.0.2.1 unreachable distance=20 scope=40 target-scope=10
bgp-as-path="65333" bgp-med=0 bgp-origin=igp bgp-communities=65333:888,no-export
received-from=80.81.197.33
1 Db dst-address=1.0.0.0/8 gateway=192.0.2.1 unreachable distance=20 scope=40 target-scope=10
received-from=81.91.160.38
2 Db dst-address=2.0.0.0/8 gateway=192.0.2.1 unreachable distance=20 scope=40 target-scope=10
3 Db dst-address=2.0.0.0/8 gateway=192.0.2.1 unreachable distance=20 scope=40 target-scope=10
Anybody can help?
Yes, because the 192.0.2.1 is probably blackholed and it’s not reachable right ? I don’t think those instructions on the cymru stuff are 100% right. I will test a few thing and see if I can get a workable solution. We simply use the BGP to get the list, convert them to a address-list and then drop in the firewall.
I heve tested both. 192.0.2.1 blackholed and assigned to bridge interface.
In BGP should not be a problem to set next-hop to prefixes received via BGP right? I use routing-test 3.20.
The route to 192.0.2.1 is active in routing table. I don’t understand this situation. Using address-list is bad idea in my opinion.
For 35 routes it’s not a problem but in case I want to set next-hop for 18000 prefixes? I think doing address-list is not a replacement.
no, we use the incoming routes to build an address-list so that we can also use these prefixes in the firewall… it’s in addition to, not replacing. We’d rather block the traffic as it’s coming in, not trying to leave. (we do both however).
/routing filter
add action=accept chain=cymru-in comment=
“Cymru Chain - Mark bogons with a different routing-mark” disabled=no
invert-match=no set-bgp-communities=65333:888
set-type=blackhole
You can simply use that routing filter above to tell it to make it a blackhole route. No gateway, interface, next hop, or anything else needed.
Oh You have right. There is no option set-type=blackhole in winbox. I did’t check in command line.
Thanks. Now it works.
below is a modified version of that document.
now what i want to know is how to reflect these prefixes to another router. It seems like if you have anything in a routing-mark or blackhole type table you can’t reflect the list.
# 2009-02-06 Modified by Sam Norris. Removed static routes
# and used "set-type=blackhole".
set default as=<YOUR_ASN_NUMBER> router-id=<Your router wan ip address>
/routing bgp peer
add comment="TEAM-CYMRU BOGON Server #1" hold-time=3m in-filter=BOGON-SERVER-IN \
add comment="TEAM-CYMRU BOGON Server #2" hold-time=3m in-filter=BOGON-SERVER-IN \
/routing filter
disabled=no invert-match=no set-type=blackhole
add action=discard chain=BOGON-SERVER-IN comment="" disabled=no invert-match=no
