BGP Prepend not working (CCR with RouterOS 6.5)
CCR 1036
RouterOS 6.5
BGP Prepend Filter is not having any affect. I’ve confirmed this with both upstream providers (Cogent and TWTelecom). When I have a filter setup they are not seeing any prepend on their end and the traffic is still the same when a prepend is set or not, so I’m not able to depriortize a particular network on provider
add network=38.121.0.0/20 synchronize=no
add network=38.121.16.0/20 synchronize=no
/routing bgp peer
add in-filter=cogent-in name=“cogent” out-filter=cogent-out remote-address=38.104.232.97 remote-as=174 ttl=default
add in-filter=tw-in multihop=yes name=twtelecom out-filter=tw-out remote-address=64.128.204.49 remote-as=4323 ttl=default
/routing filter
add action=accept chain=tw-out prefix=38.121.0.0/20 set-bgp-prepend=4
add action=accept chain=tw-out prefix=38.121.16.0/20 set-bgp-prepend=4
add action=accept chain=tw-in
I’ve tried both ‘accept’ and ‘passthrough’. I’ve disabled and reenabled the peers. 80% of the traffic prefers the TWTelecom route even when I prepend=1, 2, 3, or 4. TWTelecom says they are not seeing the Prepend. Cogent said the same when I tested another ip block we BGP with them.
Any ideas on what to try?
Disable the filter the enable it
We have tried disabling and enabling the filters, it doesn’t help, prepend still not working.
Hi Brian,
I just looked over your filters and they do indeed look correct.
The other thing we have had work is moving the policy order.
I often will paste in a bunch of filter rules that work perfectly on another router, then have to move them around enable/disable them in winbox to get them working.
