BGP Problem, connected but no /ip route
Hi…
I’m using v2.9.11 use BGP with my isp and already connected with 1951 route receive, but when I go to /ip route and print, I can’t see the route I receive, anyone have the same problem ?
Thank you for your kind attention & help
Eko
Hi ,
I have also the same problem before, as i know in the mikrotik version 2.9.xx the bgp routing is in developing, so the bgp is not perfect. if you want to use bgp you can use mikrotik with old version 2.8.xx (quite stable)
hopefully help you
Yes…
I downgrade my router to version 2.8.28 , I upgrade because I think version 2.9.11 is stable already… don’t know that there is bugs in the bgp :frowning:, also my upgrade expired on feb 1, 2006
Everything work fine now… thanks for sharing
