i have set bgp local pref in one prefix , but mikrotik still use other route as best:
[amix@router001] > /ip route print detail where dst-address=185.121.84.0/24
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
0 ADb dst-address=185.121.84.0/24 gateway=XXX gateway-status=XXX reachable via retn-m9 distance=20 scope=40 target-scope=10 bgp-as-path="9002,31261,199975" bgp-weight=110 bgp-local-pref=110 bgp-origin=igp
bgp-communities=9002:0,9002:64667 received-from=retn-m9
1 Db dst-address=185.121.84.0/24 gateway=YYY gateway-status=YYY reachable via juniper distance=20 scope=40 target-scope=10 bgp-as-path="65001,48467,31261,199975" bgp-weight=120 bgp-local-pref=120 bgp-origin=igp
bgp-communities=48467:20000 received-from=juniper
[amix@router001] > /system routerboard print
routerboard: yes
model: CCR1036-8G-2S+
revision: r3
serial-number: D83A0D0C3C9D
firmware-type: tilegx
factory-firmware: 6.45.9
current-firmware: 6.48.2
upgrade-firmware: 6.48.2
why its chosing active route such way?
